krbk on 1 meter dish and titanium lnbf cband review.
$835.00
danristheman
3,147
1,146
85w
I have been working on this for the past few months since I got the titanium c band lnbf so here it goes. this is my review. First channel I got right off the bat with my dish and lnbf was krbk out of the Ozarks that is what I was looking for. I blind scanned and I got about 50 channels it was an improved over my others that I have tried before nothing in the high symbol rate you would need a bigger dish for that. Since I live apartment I can't have a big dish so I stuck working on the small scale. This lnbf works out great for a small dish I am able to pick 6 or more sats with it on the c band side only the strong transponders. If you have a small ku dish this would work out great for it. I recommend this lnbf to anyone in this hobby.
Dan
here are some pics
Amiko is at 91w, geosatpro lnb 87w, avenger is at 83. I got 73 to 74 q on 91w at the abc news news transponder. Lpb on at 87 0 to 15 q barely anything on 83w.
Reactions: northgeorgia
Cool set up..Congratulations!!.. Did you test the signals without the "butternut" cover to see if your quality improves little bit?
Please look at the dish its a fake logo I painted it on there. The cover does' t block the signal works great I say I get most of 99w expect the high symbol rate stuff.
No it fits just with a little bit of fanagling it pops right in no cutting or modifying. Signal goes right thru with no problem.
Looks nice! What size is that dish?
Oops, never mind, just saw the title of the thread, 1 m. :biggrin
Looking good Dan.
Dan. I got to do the same. At least attempt to do cband on small dish. HOA will not allow Cband and unfortunately have 10 ft in garage. Anyway, I am curious as to how your sidecar is affixed to your satellite. I can't tell by the pictures how you attached to the lnb holder and/or arms. Is it possible to get a closeup picture that better demonstrates this? Thanks.
Reactions: danristheman
Please check out pic 33 it shows how everything is mounted on there. buy a bracket fit it on there the best you and do the measurements there. Send me a pm if you need more info. Twist ties help out and zip ties also.
Thanks Dan. That helps. I thought I saw twist and zip ties. I have the same bracket setup. I can figure this out. If I run into any issues, I'll give you a hollar.
Plug and play kind of thing its neat what you can pull in give a pm I'll send you more ideas to go round hoa's.
Possibly saving a dish!
Dish Pointer App Support
