Ku Issue
JFOK
1,144
902
Cape Cod - MA.
Hi all,
The past few mornings I've turned on my TV and found that I had no Ku signal. The night before all was well. C Band is fine.
Does anyone have an idea what may be causing this ?
I checked my Ku connections out at the dish and all looks good... no corrosion. After I reconnect my Ku connection at the dish, it works once again with a strong signal.
Could my 22Khz be failing ?
Thanks in advance.
John
Hi Brian,
Thanks for responding
Been going back and forth with yard and satellite dish work today and just discovered the problem. On close inspection, I found the coax connector came loose on the Ku coax out at the dish, just enough to affect the signal. Don't know how, but it did. It's now well secured.
Hope all is well with you.
John
Reactions: Titanium and FTA4PA
Hi Brian,
John
Glad you figured it out. :)
Reactions: JFOK
Which method(s) do you use to point your dishes?
Telstar 12 Vantage from Miami
