Lcd tv does not detect MICRO HD
captainkreid
ontario
Finally got the mine today, however disappointed when the lcd tv would not detect the micro.
Tried 2 different lcd sets with 2 different hdmi cables. AV was also not detected.
Power and usb lights are on but screen is blank...very frustrating.
Just wondering if any one has a similar problem or knows of a solution.
Plug in the composite cable that comes with it, then go in and change the settings to 720p, its possible your TV does not handle 1080p which I believe is the default setting. Then try the HDMI again. :)
Up and running now with a menu screen in 720p. Both 42" LG (42LH) and 26" ocalypso (CLP-26LC1A) will not detect either in RCA (AV) or 1080. Finally tried a third older model TV and was able to get a menu with AV connection.
So I am good to go, thanks for all the help.
thats weird it didnt detect the a/v cables. Make sure the 1/8" plug is pushed all the way in the back of the Micro
microhd changes satellites when scanning tp
Olympics Feed Freezing The Micro
