locking problem
steelhead51
4
Lewiston Mi.
I cant get sats 110 and 119 to lock at same time both get same signal 84% but only one will lock on a time one shows white bars on green background other white on red try to adjust the it locks on just goes back and forth. Is this a switch proble bad dish ?
You have posted basically the same question twice try staying with only one question and answering the questions you are asked. You will get more and better answers as we narrow down your problem. Getting signal on the wrong LNB or a wrong switch connection could be your problems but we aren't there to see what you have so asking questions is the only wa we can try to see what is right in front of you.
it sounds like you are using the recvr to point with ... what we need to know is the type of lnb you are using ... it sounds like you might have your el or skew off... or misaligned & you might be picking up the sats with only one lnb ...
FSN North Wisconsin
Sat 119 Question ?
