LOF settings
timmy1376
698
Manhattan, KS
I have Progdvb working with my DVB World card on my laptop, but on the desktop, it doesn't seem to even thing the box is active. But my question is, on SBS last night, I had to have my LNB type set to Circular to get any channels like ONN. Can someone post a screen of their setting in either progdvb or the Nextorm software? What do I use for LOF1 and LOF1. How about switch?
thanks!
If you mean you were on SBS6, then a setting of Circular for LNB type would be wrong as that sat is linear Ku. What lnb do you currently use? If it's a standard
linear Ku LNB, then the L.O. setting should be 10750. No need to use the switch setting unless you are using one.
It depends on your entire setup. Dish & motor, DiseqC switch and LNB.
grusome
LNB cover modification
Clip on OTA antenna
