mass storage device
simple
1. plug in drive
2. format drive
3. use drive
but note it does bypass the internal drive
one other thing to be aware of.. You cant use the external drive as a backup...
As soon as you plug it into another receiver it will format again and erase everything
:welcome to Satelliteguys flicmo!
Also, the ehd has to have an esata connection.
simple
1. plug in drive
2. format drive
3. use drive
Process I use ...
1. Shut down recvr (unplug )
2. Plug in drive
3. Plug in Recvr
Recvr should see the new hard drive once it boots up and format drive
4. Use drive.
A reboot above may work, but you have to plug in drive before it starts to start up again.
2 tb is the limit for the regular hd dvrs IIRC. I don't think there is a limit for the Genies.
What is the largest size external drive you can hook up to a HR23 ?
I have had good luck with 1.5TB EHD's on my 24's.
I would imagine that there IS a limit for the Genies, though it may not be known yet.
I think like Chip said, 2TB was the limit on the up to 24's.
Process I use ...
2. Plug in drive
3. Plug in Recvr
4. Use drive.
Same here, I've tried a 3TB on the HR20-700 and HR24-500 with no luck so 2TB's is still the limit...
Geesh, I didn't even know they made 3TB's.
Can you imagine having the HD go down and losing all those stored shows.
As always, Never keep something you HAVE to have on a storage device very long, you never know when you may lose your hard drives, this goes for any providers.
The providers are NOT responsible for lost programs.
While I was researching for esata drives I ran across a 12tb drive ( but they grab you by a very tender area and squeeze Really hard for that one) LOL
I took the plunge...
Self Install H25 Receiver in Motorhome
