Memphis, TN NBC Down?
ravma479
14
Can anyone confirm if the Memphis, TN NBC affiliate, WMC-DT, is down? I haven't been able to receive a signal since yesterday. It just cut off.
This is a common occurrence for NBC in the Memphis area. It goes and comes without warning. NBC is the worst in my area.
I always receive CBS and ABC.
FOX is up and running but at very low power. You must be very close to the University of Memphis to receive the signal. ( I'm not.)
I am very, very close to the U of M and I cant get it. My antenna is even 20 feet up. I thought their digital broadcast tower was on Mt. Moriah, however.
FYI, NBC is still down, It's day 3. See, this is why I think we need to be able to get national feeds on satellite... but alas.
Btw, is there any antenna you know of that might do the job? I'd really like to be able to get FOX.
Try to get a waiver from that NBC station. Tell them that you need it only to get the national NBC-HD channel from your satellite provider. If they won't do it go through your sat provider. I did that and was able to get CBS distant net including their HD channel because my local CBS station ignored the waiver.
I spoke with the engineer last week and they are waiting on a part to arrive. I was not able to get an estimated time for the parts arrival.
WMC-DT goes down alot! I was amazed that it stayed up the entire Olympics. Check out this link http://www.avsforum.com/avs-vb/showthread.php?s=&threadid=167943&highlight=memphis for Memphis HD viewers.
Hopefully WMC-DT will be up by the premiere of ER.
Do you think there is a chance we can get a waiver for the national feed on D* since the tower goes down so much and the signal is so hard to get? I'm only 2 miles away from it but I have a hard time keeping the signal.
Grounding a mast
OTA Digital in Philly Area
