Is the microHD still the cheapest and best HD receiver out today?
Yes3. Is there a channel list for the receiver?
Bypass as in no processing or levels being set to unity. For example, the "Brightness" level control has a range of 0 to 100 so at what brightness setting represents a digital out of 16?Please explain "pass through of the digital video"?
OK, you lost me on that one. AFAIK, 0V = Reference Black. From SMPTE 274M:STB builds are usually based on 8-bit 4:2:0 YCbCr outputs and there is little reason to provide an expanded range as the broadcast material is typically produced and broadcast for the 54mv video black level set-up.
10.5 For the Y' component, reference black (zero) in the expressions of clauses 5 and 6 shall correspond to a level of 0 Vdc, and reference white (unity) shall correspond to 700 mV.
I will have to look into this. I have two Western Digital green drives in my NAS and will look at their documentation. If you know of a manufacture and series of drives that do this it would help.The microHD does provide USB power management (sleep mode). Compatible drives will spin down until a DVR event or media playback. The USB power is usually always present on any consumer device. Not sure that I have ever observed USB power being shut off on a port while a STB is in operation mode.
Consumer electronic devices with an user adjustable setting is not by design to be a calibrated reference. It is for the eye of the user or for reference and adjustment with an external calibration device. At the default position 50 - there is no amplification or attenuation.Bypass as in no processing or levels being set to unity. For example, the "Brightness" level control has a range of 0 to 100 so at what brightness setting represents a digital out of 16?
The NTSCm standard, used in North America, does not set black at 0IRE (0V), but rather at 7.5IRE (54mV). ATSC black reference (and computer RGB) is set to 0IRE (0V). The rest of the world references black at 0IRE (0V)OK, you lost me on that one. AFAIK, 0V = Reference Black. From SMPTE 274M:
NAS enclosures are usually set-up different as they are often required to be spinning 24/7 and are not desired to spin down. Often they have a rear panel swoitch or software setting for user setting. On standard usb enclosures it is a function of the USB controller, not the drive. I have several USB devices that I swap around here at home that spin down: Maxtor One Touch4 Plus 500GB, Hitachi SimpleDrive 500GB, iomega eGo 500GB, WD My Book Studio Edition 500GB (USB, Firewire, eSATA), Hitachi 500gb Xmobile. Some have software tools allowing user selectable settings controlling the sleep function.I will have to look into this. I have two Western Digital green drives in my NAS and will look at their documentation. If you know of a manufacture and series of drives that do this it would help.
