moving..want to keep current DirecTV local channels..
Y
yankees2006
Thread Starter
Jun 17, 2006
OK, I may be moving from NYC to the west coast and want to keep the NYC local channels on at least one TV while I'm living on the west coast and especially want to keep YesNetwork. Is there anyway to do this? I have access to a billing address in NYC, would that be enough?
Anyone know?
J
jckm78
SatelliteGuys Guru
Apr 21, 2006
136
just don't tell directv you are movingt to the west coast. install a dish in your new place and you should receive the same programming as before, including NYC locals.
charper1
charper1
Bourbon Tester
18,442
6
I'm Nationwide
You should keep everything except the SD LILs that ARE NOT one of the big 4 networks, because of spot beaming. Not 100% sure how HD LIL would be for you outside of the NYC area; there are both MPEG2 feeds that are CONUS, and there are MPEG4 feeds that are spot beamed. Do you have MPEG4? If so, might you lose those too?
charper1
charper1
Bourbon Tester
18,442
6
I'm Nationwide
You should keep everything except the SD LILs that ARE NOT one of the big 4 networks, because of spot beaming. Not 100% sure how HD LIL would be for you outside of the NYC area; there are both MPEG2 feeds that are CONUS, and there are MPEG4 feeds that are spot beamed. If you have MPEG4 receivers you might lose those too.? Maybe.
J
jckm78
SatelliteGuys Guru
Apr 21, 2006
136
What are the SD LILs? are these channels on a satellite that the west coast can't pick up? Just curious.
charper1
charper1
Bourbon Tester
18,442
6
I'm Nationwide
Standard Definition Local Into Local. These are all your local affiliates that are retransmitted to you via DirecTV ; not just the big 4 (abc, cbs, nbc, fox) and those outside of the big 4 are spot beamed; or only retransmitted back into the area they serve. If you dish is physically out of said area, then there will be no signal to receive. Other than those SD LIL, I am sure MPEG4 HD LIL (via the H20 receiver) are all spot beamed.
charper1
charper1
Bourbon Tester
18,442
6
I'm Nationwide
I am also not 100% sure how regional sports channels are beamed; maybe Iceberg can tell us. I am sure they are CONUS = Continental US (national)
M
Mr Tony
378
109
Mankato, MN
RSN's are CONUS (sicne they have to be in Multisport pack) so that would be fine
charper1
charper1
Bourbon Tester
18,442
6
I'm Nationwide
So Ice; is my assertion correct on his/her SD LIL outside of the B4?
Y
yankees2006
Thread Starter
Jun 17, 2006
OK, little confused.
I just have DirecTV with Tivo (2 rooms), NYC local, MLB xtra innings. Standard (not HD).
What I want to do is still be able to receive YesNetwork without being blacked out and local network (ABC, CBS, Fox, etc.).
I have access to a billing address here in NYC and would just want one accessible to this feed.
Do I have them install on the west coast and then pop in my NYC card?
I'm absolutely clueless on what to do.
M
Mr Tony
378
109
Mankato, MN
yes. The Big 4 would be CONUS for distants but the rest are probably spotbeam
M
Mr Tony
378
109
Mankato, MN
Are you going to have it professionally installed on the west coast? If so, you might have some issues because they will have to change your address. If you do self install, you should be fine.
it doesn't work that way. If you have it pro installed, they have to come to your new address and that is what will be on record. (not NY)
Y
yankees2006
Thread Starter
Jun 17, 2006
OK hear me out.
I have them install it under another name (spouse) and then just take one of the boxes with the card under my name that is being paid for in NYC.
Would that work?
charper1
charper1
Bourbon Tester
18,442
6
I'm Nationwide
No, cards are permanantly "married/assigned" to a specific receiver. The only time you can change them is when DirecTV sends you updated cards, then the old ones will be killed in their system. You can't swap legit cards from one to another and back.
If the subscription still has the NYC area zip code attached, you will still be subject to that old area's blackout rules. BUT you should toss up am OTA antenna to get the new area's locals whicle getting the NYC networks at the same time.
Similar threads
jamieh1
Replies
Views
1K
Dembinskij76
D
B
Replies
6
Views
1K
raoul5788
raoul5788
dishfan82
Replies
37
Views
1K
John2021
HopperGenie
Replies
5
Views
255
comp9
C
