Need Help for setting up coolsat 4000 pro for G3c
dongbeihu
6
Help setting up coolsat 4000 pro for G3c
I have been trying to aim the dish at G3c with a fortek Star 80cm offset dish.
I got up to 97 % on signal level and quality flashing up and down 25%. Got my position from satellite finder caculator. I wonder If I doing everything right. I just could not lock on to GC3 by doing manual scan :confused: . I am new I don't know if you have to input anything to the receiver or just use whatever default setting in there? I have been trying for a few days now and get really frustrated with this thing. Any help will be greatly appreciated.
I got up to 97 % on signal level and quality flashing up and down 25%. Got my position from satellite finder caculator. I wonder If I doing everything right. I just could not lock on to GC3 by doing manual scan. I am new I don't know if you have to input anything to the receiver or just use whatever default setting in there? I have been trying for a few days now and get really frustrated with this thing. Any help will be greatly appreciated.
Welcome :wave
I am assuming you are trying to get CCTV? That is a real strong signal (gives me a 80 quality on my Coolsat).
If you go to manual scan, the transponder should be in there
11780 frequency
H
20760 symbol rate
Where are you located (zip would work or general area). Then we can see if the elevation and stuff is right.
http://sadoun.com/Sat/Installation/Satellite-Heading-Calculator.htm
can help too.
The thing with the Fortec dishes is some of them the elevation is off by a couple degrees. My 36" is like that. G3 for me is at 38 but the elevation looks like its at 35.
Help
I will try again. I will let you know if I got it. The thing I encountered before was when I try to input the frequency 11780 the receiver will nor let me and tell me it is a invaled frequency. Could you tell how did you changed frequency in there. :confused: Also the G3c/c in the coolsat is the same as G3c? My zip is 66614. Thank you very much.
dongbeihu said:
Thank you for your help very much I will set up and try again. I will let you know if I got it. The thing I encountered before was when I try to input the frequency 11780 the receiver will nor let me and tell me it is a invaled frequency. Could you tell how did you changed frequency in there. :confused: Also the G3c/c in the coolsat is the same as G3c? thank you very much
whoops.....there might be 2 in there
do this
Go to install setup and bring up G3
If you have a regular LNB (not Universal), set it up just like the picture (well, actually have the DiseQc part off)
attachment.php
If its universal, change the LO from 10750 to 10600 and make the 22k on
Then you should be able to put in 11780 (it sounds like it ss et for C-Band right now)
Topeka, KS 66614
Latitude 39° 0.924'N Longitude 95° 44.814'W
Sat Name Sat Lng Az(t) Az(m) El Skew
*** Of Particular Interest ***
EchoStar 3 61.5W 132.8 128.6 32.6 -34.8
EchoStar 6 110.0W 202.0 197.8 42.4 16.9
EchoStar 8 110.0W 202.0 197.8 42.4 16.9
EchoStar 7 119.0W 214.3 210.2 38.8 26.0
EchoStar 5 119.0W 214.3 210.2 38.8 26.0
EchoStar 9/Telstar 13 121.0W 216.8 212.7 37.8 27.8
EchoStar 1 148.0W 244.0 239.9 20.2 44.3
EchoStar 2 148.0W 244.0 239.9 20.2 44.3
EchoStar 4 157.0W 250.9 246.8 13.5 47.3
DirecTV 3 81.8W 158.5 154.3 42.5 -16.6
DirecTV 2 100.8W 188.0 183.8 44.5 6.2
DirecTV 1R 100.8W 188.0 183.8 44.5 6.2
DirecTV 1 101.0W 188.3 184.2 44.5 6.4
DirecTV 4S 101.2W 188.6 184.5 44.5 6.7
DirecTV 6 109.8W 201.7 197.5 42.5 16.7
DirecTV 5 119.0W 214.3 210.2 38.8 26.0
*** All Satellites 61W - 160W ***
Rainbow 1 61.5W 132.8 128.6 32.6 -34.8
Brasilsat A2 (incl. 5.8 deg) 63.0W 134.4 130.2 33.6 -33.7
Brasilsat B2 65.0W 136.6 132.5 34.8 -32.3
Brasilsat B1 70.0W 142.5 138.4 37.5 -28.2
Nahuel 1 71.8W 144.8 140.6 38.4 -26.6
AMC 6 72.0W 145.1 140.9 38.5 -26.4
Galaxy 12 74.0W 147.6 143.5 39.5 -24.6
SBS 6 74.0W 147.6 143.5 39.5 -24.6
GOES 12 75.0W 149.0 144.8 39.9 -23.6
AMC 5 79.0W 154.5 150.3 41.6 -19.6
Nimiq 2 82.0W 158.8 154.6 42.6 -16.3
Brasilsat B3 84.0W 161.7 157.6 43.2 -14.1
XM Roll 85.0W 163.2 159.1 43.5 -13.0
AMC 9 85.0W 163.2 159.1 43.5 -13.0
AMC 3 87.0W 166.3 162.1 43.9 -10.6
Galaxy 9 91.0W 172.5 168.3 44.6 -5.8
Galaxy 11 91.0W 172.5 168.3 44.6 -5.8
Nimiq 1 91.0W 172.5 168.3 44.6 -5.8
Brasilsat B4 92.0W 174.1 169.9 44.7 -4.6
Telstar 6 93.0W 175.6 171.5 44.7 -3.4
Galaxy 8I (incl. 1.0 deg) 95.0W 178.8 174.7 44.8 -0.9
Galaxy 3C 95.0W 178.8 174.7 44.8 -0.9
Telstar 5 97.0W 182.0 177.8 44.8 1.5
Inmarsat 2 f2 (incl. 1.7 deg) 98.0W 183.6 179.4 44.8 2.8
Galaxy 4R 99.0W 185.2 181.0 44.7 4.0
AMC 4 101.0W 188.3 184.2 44.5 6.4
AMSC 1 101.1W 188.5 184.3 44.5 6.6
AMC 1 103.0W 191.4 187.3 44.2 8.9
Solidaridad 1 (incl. 2.8 deg) 103.5W 192.2 188.1 44.1 9.5
AMC 2 105.0W 194.5 190.4 43.8 11.2
G-Star 3 (incl. 11.5 deg) 105.0W 194.5 190.4 43.8 11.2
G-Star 1 (incl. 6.0 deg) 105.0W 194.5 190.4 43.8 11.2
MSAT 1 106.5W 196.8 192.6 43.5 13.0
Anik F1 107.3W 198.0 193.8 43.2 13.9
Anik E1 109.2W 200.8 196.7 42.7 16.0
Anik E2R 111.1W 203.6 199.4 42.1 18.1
Solidaridad 2 113.0W 206.3 202.1 41.4 20.1
Morelos 2 (incl. 4.4 deg) 114.9W 208.9 204.7 40.6 22.0
XM Rock 115.0W 209.0 204.9 40.6 22.1
SatMex 5 116.8W 211.4 207.3 39.8 23.9
Anik E2 118.7W 213.9 209.8 38.9 25.7
Galaxy 10R 123.0W 219.3 215.1 36.7 29.5
Galaxy 5 125.0W 221.7 217.5 35.6 31.1
Galaxy 12 125.0W 221.7 217.5 35.6 31.1
Galaxy 13 127.0W 224.0 219.8 34.5 32.6
Telstar 7 129.0W 226.2 222.0 33.3 34.1
Satcom C3 131.0W 228.3 224.2 32.0 35.5
Galaxy 1R 133.0W 230.4 226.2 30.7 36.8
Satcom C4 135.0W 232.4 228.2 29.4 38.0
GOES 10 135.5W 232.9 228.7 29.1 38.3
AMC 7 137.0W 234.3 230.2 28.1 39.1
AMC 8 139.0W 236.2 232.1 26.7 40.2
Inmarsat 2 f3 (incl. 1.9 deg) 142.0W 238.9 234.8 24.6 41.7
TDRS 9 (incl. 7.4 deg) 151.0W 246.4 242.3 18.0 45.4
TDRS 10 (incl. 6.2 deg) 151.0W 246.4 242.3 18.0 45.4
Satellite Finder is (c) Copyright 2004, P. Lutus
It sounds like you are trying to input in a KU frequency on a c band sat designation. G3 is both c and ku, does the coolsat have a g3/ku sat that you can select?
[edit, iceberg beat me too it, thats what happens when i wait toolong to hit the submit button]
Unfotunatelly not…Its set for C-Band I think and to have KU you either
-have to add a satellite
-change the LO frequency
thank you!!!
I have a feeling this will work I got the frequency stuff in there now :) I Got it G3c and all the chanells, Thank you!!!!!!!! :)
I've gone as far as deleting all the transponders and adding a few key ones for a sanity check.... then blind scanning.
I did this when I separated G11 from Nimiq 1/3. I used G11C for G11Ku.
What can I get with an 18" dish???
need some motor parts
