Need some help!!!
micklel
8
C band system w/4dtv. No picture or picture tiling all satellites. Shut off ordered new LNB. Turned on when LNB arrived, all satellites good except C4. Picture tiling. Installed new LNB. Same story. All satellites good, C4 tiling. Checked cable. Good. Help!!!
Have you checked to make sure you don't have anything blocking C4 and your limits haven't changed on you. What channels are tiling on you, all or just certain one's? What size dish and feedhorn ( do you have a servo motor ) are you using also your location? Check to make sure everything is tight on the dish, mount,actuator and no excess movement.
Thanks Sergei. Finally got up with my satellite guy and he confirmed the fact that the dish had moved in the wind, Up and running now. All ok.
