netstream 2000 graph help needed
scupmando
56
I'm trying to setup my netstream 2000 card to work with either mytheatre or dvb dream using a twinhan 102g. I just can't seem to figure out how to build a working graph using graphedit. All codecs and drivers are installed properly I think. Any help would be greatly appreciated.
MyTheater Version 3.25 has a graph for Netstream 2000,
Graph is source-sigma hardware decoder- video renderer.
You don't need the video render on the overlay if you are
just using it with a tv on the netstream video out.
Thanks for the info Wayn23.
Would you happen to know where I could find the 3.25 version of mytheatre. I found 3.25.1, but can't find any earlier versions than that.
Graphedit wouldn't let me select source as a filter. Says it is in use. Maybe I should uninstall all programs that use the source, build the graph, then re-install mytheatre and dvbdream?
I just checked, I have 3.25.1 also. I noticed that the graph is named
W2K Netstream in the graphs, when I looked it was grayed out in the
graphs list so I opened it in graphedit and resaved it as Sigma.xgr and
then loaded it in MyTheater and it showed up in the list and worked fine.
I finally got it working. What a difference the netstream makes on cpu usage.Thanks again!
Question for jerryt
It's a great day for true FTA!
