New 4DTV Map Restoration Program
  • Thread starter Thread starter azcoder
  • Start date Start date
  • Replies Replies 0
  • Views Views 5K
azcoder
27
Prescott, AZ
Hello all,
A new version of the 4DMapMaster Restoration is now available. It is at the same place as the original version. If you do not know where that is, send me an e-mail for the URL to MapMasterWizard (at) gmail.com and I will send it via return mail.
We continue to move forward with the map master program. I have provided some bug fixes and some new functionality. As before, there are Linux and Windows versions. So Enjoy!
Here are a few of the changes:
- Change display order of combined output from Sat ID order to Orbit Location order.
- Add better DSR-921 support.
- Change timezone offset change to be +/- to allow Europe users.
- The DSR-905 time is now handled correctly as well as the DST/NON-DST settings.
- Improve time location information for master reset units.
- Correct the allocation order of the SIT table entries.
- Added more diagnostic code.
- Enhance the testing of field values for being valid in SIT/Channel entries.
- Use the P?/U? field in the SIT entry instead of ignoring it.
- Change calculation estimate for satellite locations. Use 4th order polynomial curve fit instead of least squares fit.
- Fix error where SIT/Channels would not load anymore data after a blank line in the maps file.
- Output MM release information in output.
- Output 4DTV model and firmware revision of nvram.
- Put path name of binary nvram in display/dumps of output.
- Handle dumping of smaller (128kb) DSR-405 nvram.
- Correct and enhance documentation of various field/bit assignments of various tables.
- Change output of table dump tag information and labels.
- Correct TDT allocation code.
Probably more, but that is all I can think of at the moment.
If you have any suggestions for future enhancements or bug fixes, let me know. When we get enough changes, I will generate a new release.
MMW
Corotor performance question
Adventures In Dish Hunting 2012
