Next Generation GEOSATpro Satellite receiver
T4Runner
1,034
58
37.0N 119.5W California
Any word on the next receiver to be coming out this Spring from SatelliteAV? I received a small $$$ at work and have $$$ will spend...
I love the MicroHD, but am always looking for the newer, bigger, best, with bells and whistles...
The GEOSATpro HDVR1200 will be released for Glorystar service in March, 2013. Hobbyist full FTA experience will be available shortly after the release.
The HDVR1200 supports: QPSK, 8PSK, H8PSK, 16APSK and 32APSK
MPEG2/4 and h264
480i - 1080p
Update via satellite of Firmware and Glorystar Channel list.
Supports simultaneous automatic Glorystar channel list updates and retaining the User Channel list, LNB, switch, favorite settings.
Closed Captioning EIA608 and EIA708 via HDMI, Component and Composite outputs.
Dolby /AC3 Internal Decoding and raw output via HDMI, SPDIF Optical.
FCC, Dolby, HDMI, UL Cert and licenses.
No 4:2:2, VCM or MIS support planned at this time.
Re: Next Generation MicroHD Satellite receiver
Can't view the pictures with the satelliteguys app.
Sent from my Nexus 7 using SatelliteGuys
With Tapatalk you can. Nice looking unit Id say :D
Sent from my SPH-L900 using Tapatalk 2
Looking forward to experimenting with one of these.
Thanks, Brian. I will keep that in mind. I swapped out the 27 inch Tube for a LCD/LED 20 inch for the microHD.But the back TV is not swapped. Will remember that for when we take it on the road... If I do not change out the TV first! (need a 25 inch up front!!)
Brian, I've read a couple posts by you condemning serial ports on hacker boxes. Why does this have one? Does it make it easier to fix the box if something goes wrong? Maybe no need for the usb ttl converter like the microHD?
Just wondering, Catamount
HUH??? You will need to give some examples of my serial port condemnations.
http://www.satelliteguys.us/threads...-com-has-been-hi-jacked?p=2624458#post2624458
Simple answer: The microHD is... well, micro. :D We chose TTL port on the PCB to minimize the footprint.
Maybe you're thinking of a WiFi connection?
I apoligize, Brian!! Somehow I had it in my mind that you were against serial ports. Personally, I believe it is a good backup for loading firmware if the USB port might go bad. I have the third Pansat 1500 ever made, and back then it was all serial ports. When my power supply went bad years ago, and I replaced it , it wouldn't load by serial. I had to learn about j-tag.
After three months I fixed it and it's still going strong.
Catamount
MPEG2/4 and h264
480i - 1080p
This is what I was waiting since day one!! This one suits all my needs (Component Output, RS232,) in addition to all their wonderfull features. Congrats!!! I will be in line too!!
SAT-7 Channel coming to 97 West
Hose clamp as a protractor for pointing Ku dish to azimuth
