NICE AND EASY: DIRECTV and DISH on the same wire?
$835.00
A few weeks ago I was contacted by one of our support staff. There was a customer on the line who operated an RV park and wanted to know,
I want to offer my guests a choice of DIRECTV or DISH. How can I put both on the same cable so they can just choose the one they want?
Easy answer: you can't. DIRECTV and DISH share the same frequencies so you can't put both on the same cable. Neither would work. If the RV park wanted to put either satellite or TV antenna on the same cable, there are some options (although it's still hard.) But two different satellite services aren't going to live on the same cable, period.
It does bring up some other questions, though:
Can an RV park even do that?
As a private person, you can't share DIRECTV service with anyone, and you can't charge for it. However owners of campgrounds and other hospitality services like that can do so, as long as they follow certain rules and the account is set up right. If you're an RV park owner who's interested in something like this, give us a call at 888-233-7563.
Can you even have DIRECTV and DISH in the same building?
You sure can. Not only is there no rule against it but it happens a lot, especially in situations where there are channels that aren't carried on both. A sports bar whose customers really want to see the PAC-12 channel but still want Sunday Ticket will have two different providers. It's expensive, but it happens all the time.
Bar and restaurant owners use matrix switchers to distribute programming from many different sources to many different televisions. If you'd like to know more, that's right the number is 888-233-7563.
Is there any solution that would work for a single wire in this case?
Absolutely. It's called a headend and it's like a cable TV setup just for you and your customers. You connect the DIRECTV and DISH receivers, plus over-the-air antenna if you want, into a setup that puts the channels you want onto one wire. Both DIRECTV and DISH have very compact systems, each smaller than a microwave oven. These systems can give you hundreds of channels over one wire, and the systems from different providers can even be used together. The downside is that the number of channels is limited to the number of receivers you have, but then you can easily distribute TV over a single wire and anyone with a fairly modern TV (last 15 years) can get it. You've probably seen setups like this in hotels before where there are 15-20 channels. If you want to put in a headend, you guessed it 888-233-7563.
Your commercial TV solution
No matter what you're looking for, Solid Signal can help. We're experts in helping businesses provide the entertainment options they want. We have over 20 years' experience with commercial satellite television, and DIRECTV even awarded us as their dealer of the year. Let us create a custom solution for you. Start by calling 888-233-7563 or fill out the form below and we'll get right back to you.
The post NICE AND EASY: DIRECTV and DISH on the same wire? appeared first on The Solid Signal Blog.
Continue reading...
Should you put a TV antenna on your boat?
Signal Connect Offers the Best Satellite TV Support
Who Read This Thread (Total Members: 8)
