No audio on some channels
upsss
529
68
AZ
HR44/C41, sometimes no audio on some channels. I had the same problem with the HR34/C31. It happens mostly on the client and if I change the channel Up/Dn sometime the audio gets restored. Overall, the 44/41 is much better than the junky 34/31.
I think the problem has to do with switching from HD channels to an SD channel. I am using HDMI on both TVs and there is nothing wrong with the cables. Also, I don't use external Amps and disabling the Dolby Digital setting doesn't help. BTW, never had this problem previously with Dish.
Set the box to native off and check only 1080i/1080p. That will eliminate most of the handshaking and might solve the problem. And make sure Dolby is off.
Direc everywhere
GenieGo Worth the Money?
