odd 002 error on ViP722
navychop
Stop overfishing Panthalassa!
63,962
33,313
Northern VA
Clear sky. Radar map shows no clouds. Main ViP722 in LR pops up with Signal Lost 002 error. But I can see the program behind it is still running just fine. Hitting select or cancel just makes the dialog box blink. Pressing Guide, however, makes it disappear.
I don't recall this kind of behavior before. Is this normal?
BTW, upstairs ViP722, the one with the dead fan, on the same channel, does not get a Signal Lost error at all.
Does that receiver have an OTA tuner and locals added to the guide? If so, try disconnecting the OTA module and see if it goes away. If so, it might be as simple as deleting all locals, reboot, then add the locals again, or you have a marginal signal on a local. Or, it could indicate a bad OTA tuner.
If you have a OTA antenna hooked up, tune to known strong OTA channel and then back to what you had previously on. This is a known bug since a long time and DISH will never fix that.
Both have OTA built in yet only one is doing it. But I'll try the suggestion, after my wife is done watching The Hunger Games on DVR. I've got time. Probably 3 more hours till the smoked pork is done.
Actually, we don't watch OTA on either anymore, since ER & DH went away.
It doesn't matter what you watch. The OTA tuner was tuned to a weak/intermittent channel for some reason at some point. Somebody could've done it by accident while cruising the EPG. Or, maybe the OTA cable going to that DVR has an issue of some kind.
It's just a stupid bug that used to drive me crazy when I had a 722k. Why they never fixed it is anybody's guess.
I remember now. You're right, of course.
Bonus programing for first time Dish user?
Trouble with HDMI use with 211
