OETA on K5/600-Can get on 4DTV?
Radioguy41
2,922
3,117
Lehighton, PA
Is it possible to receive OETA on K5/T600 with 4DTV? I'm having exactly the same problem that I'm having with T4/600 (Nebraska NET). The signal won't lock. I understand ACC did not map T4 correctly but is that the same issue with K5?
working fine here on the 905...ya gotta let it sit there for a little bit. Mine takes 10 seconds to pop in for some reason but its there
Well I spent an hour trying to get it tuned in with no success. It's possible I'm just not at the right spot but at 9 clicks per degree everything else is right on the money so I just don't know. What's the nearest bird with an active transponder that I could test with? I can get Doc Scott on W3, anything closer?
man ya gotta get one...With a C/KU setup there are TONS of free channels up there with a DVB box
when you get one, make sure it has blind scan (smart scan, power scan)...
OK, finally found the bird. I can't lock the signal but that's probably a dish alignment issue. It keeps coming and going. Gotta work on that. Thanks for the help.
Another Free BUD, need ID
Good Old Days or Good New Days of c-band?
