Old ui looked cleaner to me
Most installs there was never a good place to mount them, plus too much wiring it was tough to keep things looking neat. Most installs I zip tied them to the back of the dish. Then the customer would unplug the inserter and wonder why the system went down. Also couldn't work on the system with the inserter plugged in, it would zap you if you grabbed a coax.
Not sure if you know how to do this but how do I make this TV2 timer TV1
Here's the image. I want it to record on tv1 only instead of tv2 I don't use tv2.
I do happen to have an antenna connected currently. Right now I'm only getting cbs and 4 more stations instead of normal 40
The OTA tuners in these weren't the most sensitive, so don't be surprised if it picks up a lot less channels than your TV's tuner. If you're far from the towers and using an indoor antenna, that's common.
You need to tell the receiver which channels to scan prior to doing your local scan. On the 722 this option is under "HDTV setup". Look for that setting or something similar and under options change the analog type to "offair". Then scan for locals again. All of the other options scan cable frequencies. The reason you are getting one or two channels is because broadcast and cable frequencies are the same for channels 2 through 13.
I have a 612. Not a 722 if that changes any options
Weirs question but how did satellites like 129, 77, 118 die?
They didn't die. Dish rented them and no longer need them so the contract ended with the company that owns them.
Dish uses 77W for their Mexican satellite service (sat coverage isn't in the US)
118 &129 they didn't need. 118 was international programming that they moved to streaming.
That's pretty interesting. This whole time I thought 129 got hit by a piece of satellite debris. Also did customers that used to have 1000.4 turbo hds with the 77 72 61 lnb have mexican service or is that a different 77
Two Hopper Plus issues
Echostar 15 Moves to 119W
