WeeJavaDude said:Well the receive is not the only variable in this situation. One it could be the location of the houses, building and land obsticles, and cabeling. I would suggest taking your 811 over to your friends house and try it there if possible. You only need to run it a little while and check signal strength. Also, I would suggest adding a rectifier so that you can adjust the preamp. What I preamp can do is overdrive your signal and cause more harm than good. I believe the signal strength meter is a ratio of strength to errors so if you are getting a lot of errors coming over the signal strength with drop. At least this is the case with the 6000.
I agree that it could be either of those things. I'l try your suggestions. Although, when the antenna guy installed my pre amp he tweaked it for the best analog picture.
