Does Directv provide the guide data for the sub channels when connecting an AM21 for example, or is that based off PSIP data from the channel it's self ?
Again yep ...So Directv has the guide data even though the sub channels are not on the service?
Do the sub channels have specific channel numbers to pull her guide data?
They don't use the specific channel numbers to pull the guide data, they use TMS IDs - basically numbers that have been assigned by Tribune Media Services or their successors. For ones with a TMS_ID over 65535, Directv uses a defunct number under 65535 (because their guide data system apparently can't handle larger numbers) and some type of internal mapping. They've deployed that across most DMAs, but a few remain that they never got around to it and those are missing some subchannels.
Detroit DMA
WJBKDT | 2.1 |
WJBKDT2 | 2.2 |
WJBKDT3 | 2.3 |
WJBKDT4 | 2.4 |
WDIVDT | 4.1 |
WDIVDT2 | 4.2 |
WDIVDT3 | 4.3 |
WXYZDT | 7.1 |
WXYZDT2 | 7.2 |
WXYZDT3 | 7.3 |
WMYDDT | 20.1 |
WMYDDT2 | 20.2 |
WMYDDT3 | 20.3 |
WPXDDT | 31.1 |
WPXDDT2 | 31.2 |
WPXDDT3 | 31.3 |
WPXDDT4 | 31.4 |
WPXDDT5 | 31.5 |
WPXDDT6 | 31.6 |
WADLDT | 38.1 |
WADLDT2 | 38.2 |
WADLDT3 | 38.3 |
WADLDT4 | 38.4 |
WADLDT5 | 38.5 |
WADLDT6 | 38.6 |
WADLDT7 | 38.7 |
WKBDDT | 50.1 |
WKBDDT2 | 50.2 |
WKBDDT3 | 50.3 |
WKBDDT4 | 50.4 |
WTVSDT | 56.1 |
WTVSDT2 | 56.2 |
WTVSDT3 | 56.3 |
WTVSDT4 | 56.4 |
WWJDT | 62.1 |
WWJDT2 | 62.2 |
You should be able to get guide data for these stations in Detroit. If you aren't, I'd probably chalk it up to something funky about the way the COM1000 works. How you are getting the off air stations, with the COM module for ATSC or some other method?
WJBKDT 2.1 WJBKDT2 2.2 WJBKDT3 2.3 WJBKDT4 2.4 WDIVDT 4.1 WDIVDT2 4.2 WDIVDT3 4.3 WXYZDT 7.1 WXYZDT2 7.2 WXYZDT3 7.3 WMYDDT 20.1 WMYDDT2 20.2 WMYDDT3 20.3 WPXDDT 31.1 WPXDDT2 31.2 WPXDDT3 31.3 WPXDDT4 31.4 WPXDDT5 31.5 WPXDDT6 31.6 WADLDT 38.1 WADLDT2 38.2 WADLDT3 38.3 WADLDT4 38.4 WADLDT5 38.5 WADLDT6 38.6 WADLDT7 38.7 WKBDDT 50.1 WKBDDT2 50.2 WKBDDT3 50.3 WKBDDT4 50.4 WTVSDT 56.1 WTVSDT2 56.2 WTVSDT3 56.3 WTVSDT4 56.4 WWJDT 62.1 WWJDT2 62.2
Thats a nice looking rack.
Only getting guide data for the major networks
ABC
NBC
CBS
Fox
PBS
CW
Plus 2-3 independent stations.
No, I think Claude means 61 channels in all for the entire headend system, satellite and OTA ...So are you getting guide data for the channels I listed? The reason you are picking up 61 but maybe only have guide data for those 35 or so is because some of the channels you are picking up may be out of the Detroit market, and some may be low power channels which Directv does not deliver guide data for in any market.
