Pansat 2700A and Moteck SG2100
GreatFTA
1,389
15
Mississippi Delta
Hi guys!
I just bought a Pansat 2700A receiver from one of my friends.
I have installed it using a moteck Sg2100 HH drive. At first everything went fine when I programmed some satellites and using the "Smart Search" to find the TPs and channels. I fell in love with this receiver!
Then, later on I went to program more satellites. In the process, while using the USUAL feature, I accidently clicked on the "Reference Position" and ever since then all the satellites I programmed would be off like a coupla degrees!
When I smart search scan a satellite, I would end up getting the TPs and channels from the NEXT satellite! Like, I program AMC 4 into my system and do the smart search, I would end up getting the TPs and its channels from the AMC 1 satellite.
I factory resetted the receiver and tried again. Still the same bull.
I went on Pansatusa.com website and downloaded the latest software for this receiver. Still, the problem exist.
Should I reset the SG2100 again?
How can I correct this? Right now, I am doing the DiSEQc 1.2 to program the satellites. I rather use the USUAL.
Also if I use the USUAL but use the 1.2 to find tune, do I "OK" it to memory in the "1.2", or in the "USUAL" mode?
Please help!!!:confused:
In "1.2" mode positions are stored in motor's memory.
In USALS mode, they stored in receiver's memory.
Maybe, your dish is out of alignment for 2 degrees?
Move it to your "true south" satellite, and "nudge" the motor with "1.2" feature east and west. If signal improves, then probably it makes sense to re-align the dish:D
setting up motorized starchoice
Diseqc & 22k only work one way??
