Possible failing Hard Drive on HR54
Tom Speer
Staff member
Cutting Edge
Jul 26, 2016
2,019
2,952
Adirondack Mtns, NY and Eastern NC
I have noticed some brief glitches on my HR54-700 recently. Occasional slow / sluggish responses to remote commands appears to be the main glitch at the current time. That and the program guide on the HR54-700 tends to "freeze" for brief periods of time, when attempting to access and use it.
I have not noticed anything like that with my HR54-200. What you are describing fits what many people have described as their hard drives are failing. I replaced my HR54 hard drive about 7 years ago with a Western Digital Red HDD, which was marketed at that time for video surveillance continuois recording systems. A Genie server is much the same kind of duty. Today the WD Red is marketed for NAS systems with lots of users.
Since the hard drives in a DIRECTV Genie server is spinning continuously, and constantly in use, I don't like SSD's because they have a limited number of write cycles. I expect my WD Red to outlive DIRECTVs satellites.
Actually, after a brief internet search a WD Purple drive would be better suited today.
Thanks for the replies and information. Do you have any suggestions for any external "plug and play" hard drives? I have had and used the HR54-700 in my setup for a few years. The thoughts of possible hard drive failure definitely makes sense. But, with the HR54-700 just being leased on my end, if I could possibly add an external hard drive via USB connection, that seems to be the best option for me, if possible.
You can only use an external hard drive via the SATA port if your HR54-700 has one. USB will not work.
Reactions: Tom Speer
Steve615: Any authorized solution to your failing hard drive will involve the loss of all of your recordings. Some solutions which involve violation of your customer agreement also would cause the loss of your recordings.
1. The simplest authorized way to take care of a failing HDD in a HR54, is to sign up for DIRECTV's protection plan and when it is in effect, and you have definite signs of the failing hard drive, call customer service and have them send you a new HR54, if you can get one. They may try to upgrade you to a HS17 Genie server, with an additional client. That would start a new 2 year commitment AFAIK.
2. Does your HR54 have an ESATA port? I hear that some later models don't have one and can't add an external drive. If you have the ESATA port, you should be able to buy an External ESATa drive, or an External ESATA case or docking station and a high quality 4TB drive like the WD Purple I mentioned. I believe the HR54 is limited to a 4 TB drive size, don't try anything larger. Adding the external drive disables the internal one.
3. I use a couple of different Esata docks. I can't find them online anymore. The only one i see on Amazon is StarTech SDOCK2U33EB. I can't comment on quality of the Esata enclosures, Esata external Drives, or Esata Docks on the market today. THe Esata interface is largely being replaced by the high speed USB ports.
3. Replacing the Internal drive is technically quite simple, but violates your customer agreement. Here is a Youtube video showing how it is done. He uses a bent large paper clip to release the latches. I just used a flat bladed screwdriver on my owned HR54. You do need a torx securiy bit (I got some at Harbor Freight),
We have lost a lot of information on this subject from online forums. Anything that we had at Iamanedgecutter has been lost. If there is anything at the other DBS forum, I couldn't find it.
It is possible, if you remove the original drive to copy it and expand the available space to use the whole new hard drive with a PC booted into Linux and using the GPARTED program. I did it, but I had some instructions.
The partitions on the Genie HDDs are not standard Linux file systems. Copying means you have to connect the old and new hard drives to a computer at the same time.
1. The simplest authorized way to take care of a failing HDD in a HR54, is to sign up for DIRECTV's protection plan and when it is in effect, and you have definite signs of the failing hard drive, call customer service and have them send you a new HR54, if you canget one. They may try to upgrade you to a HS17 Genie server, with an additional client. That would start a new 2 year commitment AFAIK.
i've done this a few times:
That is the information I was looking for. Thank you.
Thanks for the replies and information. As for the Protection Plan, I have had that on my account since day one with DIRECTV. It has come in handy over the years, that is certain. Approximately a month or so ago, I made the decision to replace a couple of C61K clients on my account. During my phone discussions with Tech Support, it was suggested by them that I replace the HR54 with an HS17. I thanked them for the offer, but politely declined. Over the course of the last few days and nights, the glitches that I noticed and mentioned in my original post have now stopped. For the time being, I will continue using the HR54-700 as is. If the hard drive eventually dies, I will give DIRECTV Tech Support another call and have it replaced. I imagine nowadays, I would end up with an HS17 for a replacement. Many thanks again for the replies, suggestions and thoughts on this matter.
Reactions: lordodogg
looks like a new setup would be an HS-17 and the gemini and a standard HD mini unless you wanted to upgrade to another gemini. i don't think they even let you pick and choose clients anymore except for the gemini upgrade... were sticking with the C61K mini's as the gemini client made the tv go stupid :rolleyes: :shh:coco
Gemini with a peculiar issue
I can only watch 103 b even channels in low resolution
