possible to connect to below horizon satellite?
$905.00
Welcome to SatelliteGuys JustDooIt !!
That is correct. You must have a direct LOS(Line of Sight) to the satellite.
If you can't see it with your dish you cannot receive it.
52.5E is for sure way out of LOS for Cali.
Reactions: JustDooIt
might be a stupid question, could you detect an under-the-horizon satellite using a temperature inversion/troposheric ducting?
Think you'd have to be very very lucky for it to happen. There was another thread a while back where some calculated the height you'd have to mount your dish to see a satellite 2 degrees below your horizon. (IIRR almost low earth orbit range)
In theory you can pull a signal from below the horizon as the gravity of the earth will bend the signal slightly. But the negative to that is you are trying to get that signal through a lot more atmosphere and all its interference. Satellite signals are not good at terrestrial trips.
More likely to refract a C-band frequency than a KU band. Back in the analog days I remember talking with installers in Alaska that would pull in satellites calculated to be 4-5+ degrees below the horizon. The skew would be wacky and they would need to adjust frequently to track track the polarity shift in the refraction.
mikekohl has a lot of satellite experience in the Great White North. Maybe he will weigh in and tell us his installs!
thanks for the help everyone and sorry for the stupid question :P was foolish of me to actually think it'd be possible
Don't they have some on 97w ku?
indeed they do, very little though. Literally all the channels I want are on 52.5E lol, woe is me..
How do I Calculate CNR or SNR from Spectrum Plot?
It was a catastrophe, but I got lucky
