Problems locate Intelsat Americas 6 at 93.0°W
vargf
47
Hi I'm new in setup the satellites I have a Chaparral Universal LNBF
and I'm Using a Pansat 500H model and a 30" anttena I could locate the
PAS9 KU band but the Intelsat Americas 6 at 93.0°W i can't and is confuse
the setup on PAS9 is the following (note that is not a motor anttena I did a manual setup)
This is my location
Location: 34.469814 N, 117.192684 W Latitud and LOngitude
PAS9
Desde Apple Valley CA :34.469814 N, 117.192684W Latitudes
Azimuth: 94.8 with deviation -13.85 (108.6 - 13.8 = 94.8)
Elevation: 16.7
Tilt: -51.4
LNBF universal es : Low-9750 High-10600 this is the setup on the receiver.
the PAS9 at 58.0°W Set up works perfict
but on the
Azimuth:?-----125.2-----? with deviation -13.85 (141.6 - 13.85 = 125.2)
Elevation: ^ 42.3 ^
Tilt: -30.8
LNBF universal Ku band es : Low-9750 High-10600 this setup is because is universal lnbf.
is not working and now I have three day trying but nothing
any help I because is causing me a frustration. I using a bit soung to detect the satellites but this time is not working because I pass all the satellites and nothing.
Please help I need help
vargf thanks .
Hello and WELCOME to the forum!
I would make sure you are using a LIVE channel/TP. on IA-6 and double check there is nothing blocking the line of sight to this satellite!
Code:
           Latitude 34° 28.200'N Longitude 117° 0.000'W
                         Sat Name Sat Lng Az(t) Az(m)    El  Skew
                       Telstar 12   15.0W 263.1 249.3 -18.1 -54.9
                     Intelsat 901   18.0W 264.9 251.1 -15.8 -55.2
                     Intelsat 603   20.0W 266.0 252.2 -14.2 -55.3
                            NSS 7   22.0W 267.2 253.4 -12.6 -55.4
                     Intelsat 905   24.5W 268.6 254.8 -10.6 -55.5
                     Intelsat 907   27.5W  90.3  76.5  -8.2 -55.5
                   Hispasat 1C/1D   30.0W  91.7  77.9  -6.2 -55.5
                     Intelsat 801   31.5W  92.6  78.8  -5.0 -55.4
                     Intelsat 903   34.5W  94.3  80.5  -2.5 -55.3
              AMC 12 & Telstar 11   37.5W  96.0  82.2  -0.1 -55.1
                          NSS 806   40.5W  97.7  83.9   2.4 -54.8
                        PAS 6B/3R   43.0W  99.2  85.4   4.5 -54.5
                           PAS 1R   45.0W 100.4  86.6   6.1 -54.2
                     Intelsat 705   50.0W 103.5  89.7  10.2 -53.3
                     Intelsat 707   53.0W 105.4  91.6  12.7 -52.6
                     Intelsat 805   55.5W 107.1  93.3  14.8 -52.0
                            PAS 9   58.0W 108.8  95.0  16.8 -51.3
                         Amazonas   61.0W 110.9  97.1  19.2 -50.4
           EchoStar 3 & Rainbow 1   61.5W 111.3  97.5  19.6 -50.2
                 Estrela do Sul 1   63.0W 112.4  98.6  20.9 -49.7
                     Brasilsat B2   65.0W 113.9 100.1  22.5 -48.9
                     Brasilsat B1   70.0W 117.8 104.0  26.4 -46.8
                 Nahuel 1 & AMC 6   72.0W 119.5 105.7  28.0 -45.8
                        DirecTV 5   72.5W 119.9 106.1  28.4 -45.6
                            SBS 6   74.0W 121.3 107.5  29.5 -44.8
                            AMC 5   79.0W 125.9 112.1  33.2 -41.9
                          Nimiq 2   82.0W 128.9 115.2  35.4 -39.9
                            AMC 9   83.0W 130.0 116.2  36.1 -39.2
                     Brasilsat B3   84.0W 131.1 117.3  36.8 -38.4
                           AMC 16   85.0W 132.2 118.4  37.5 -37.7
                            AMC 3   87.0W 134.4 120.6  38.8 -36.1
              Intelsat Americas 8   89.0W 136.8 123.0  40.1 -34.4
                 Galaxy 11/Nimiq1   91.0W 139.2 125.5  41.3 -32.6
                     Brasilsat B4   92.0W 140.5 126.7  41.9 -31.6
                        Telstar 6   93.0W 141.8 128.0  42.5 -30.6
                        Galaxy 3C   95.0W 144.5 130.7  43.6 -28.6
              Intelsat Americas 5   97.0W 147.3 133.5  44.6 -26.5
                        Galaxy 4R   99.0W 150.1 136.3  45.6 -24.2
                            AMC 4  101.0W 153.1 139.3  46.4 -21.9
                            AMC 1  103.0W 156.2 142.4  47.2 -19.4
                           AMC 15  105.0W 159.4 145.6  47.9 -16.8
                          Anik F1  107.3W 163.2 149.4  48.6 -13.8
         DirecTV 6 & EchoStar 6/8  110.0W 167.8 154.0  49.2 -10.1
                          Anik F2  111.1W 169.7 155.9  49.4  -8.5
                    Solidaridad 2  113.0W 173.0 159.2  49.7  -5.8
                         SatMex 5  116.8W 179.6 165.9  49.9  -0.3
          EchoStar 7 & DirecTV 7S  119.0W 183.5 169.7  49.9   2.9
  EchoStar 9/Intelsat Americas 13  121.0W 187.0 173.2  49.7   5.8
                       Galaxy 10R  123.0W 190.5 176.7  49.4   8.7
                        Galaxy 12  125.0W 193.9 180.2  49.0  11.5
             Galaxy 13/Horizons 1  127.0W 197.3 183.5  48.5  14.2
 Intelsat Americas 7 & EchoStar 5  129.0W 200.6 186.8  47.9  16.8
                           AMC 11  131.0W 203.8 190.0  47.2  19.4
                        Galaxy 1R  133.0W 206.9 193.1  46.4  21.9
                           AMC 10  135.0W 209.9 196.1  45.6  24.2
                            AMC 7  137.0W 212.7 198.9  44.6  26.5
                            AMC 8  139.0W 215.5 201.7  43.6  28.6
                     EchoStar 1/2  148.0W 226.7 212.9  38.1  36.9
         Satellite Finder is (c) Copyright 2004, P. Lutus
Hi PSB I like to know what is LIVE channel/TP? because how you see I'm knew in this
and tell me if there is any guide with related to the satellite istalation in this forum
and a Dictionary with the terminologies.
thanks PBS for your advice.
Am example of a LIVE transponder (TP.) or channel on IA-6 would be.....
The University Network
DFreq: 11865
Pol: V
SR: 3516
DrDishTV Weekend Nov. 11/12/13
black screen on fortec liftime ultra from uk
