Last week I setup my new DirecTV (DTV) Streaming, Gemini steaming device and StarLink internet service.
I had problems with the local channels switching to locations other than my billing address. (With DTV the local channels are supposed to be tied directly to your billing address)
It seems to be that with StarLink the satellites that are passing by your physical location will connect to the ground stations in various places. The ground stations may be located some number of miles away. Maybe as far as 200 miles away. (Our experience was that we had the Seattle (170 miles away) then later Medford, OR, (275 miles away) local channels. We are physically located 20 miles west of Portland, OR.)
More details:
-- I am physically located about 20 miles west of Portland, OR.
-- When I first configured the Gemini and connected to my StarLink WiFi, I was receiving Seattle, WA, local channels. (Could not record any programs, but more on that later.)
-- Spent 1.5 hours in chat session with DTV. They changed my billing address to the Portland area and also had me do a factory reset on Gemini, which of course required me to repeat the Gemini configuration. I was now receiving the Portland local channels. Also I now could record programs. Somewhere in this process I learned that DTV won't let you record if you internet location is different than your billing address.
-- The next evening when I powered my Gemini back on I found I lost the Portland local channels and was receiving the Medford, OR, local channels (about 275 miles away). Also I could not record programs.
-- The following morning I was still receiving Medford local channels.
-- I decided to try a few things. I powered off my StarLink and connected to my Verizon jetpac, which I figured was bound to have a Portland internet location rather than wherever the StarLink satellite might connect to.
-- Now connected to my jetpac I still received the Medford local channels.
-- I did a factory reset on the Gemini and went through the full configuration process. Still connected to my jetpac, I now was receiving Portland local channels. I believe doing a factory reset and reconfiguration on the Gemini forced DTV computers to verify my internet location. DTV seeing I was located in the Portland area they gave me the Portland locals. Also I could now record programs.
-- Next I powered off my jetpac and powered up StarLink and connected to StarLink WiFi and I still had the Portland local channels.
At this point I stopped testing and using DTV to think about my next step. My decision is that I would cancel my DTV and just go back to my Dish Network Satellite TV, that I had been using for about 13 years.
Conclusions:
-- While DTV insists that your local channels are tied directly to your billing address. That is not totally correct. At some time DTV will check your internet location and give you the local channels for that location. The computers will are programed to compare that to your billing address and block you from recording programs if the two don't match.
-- Using a service, like StarLink, where you may make a connection to a place other than near your physical address, you may experience receiving local channels different that from your physical location and stop you from recording programs.
I hope that others will find my experience helpful.
More details:
Conclusions:
to Satelliteguys ASTravelers!
