I have a question for all you experts. I have a 522 with 2 seperate feeds (Direct from the LNB to the 522). During the day, everything is fine. At nite, I lose the 119 sat, but only on tv 1. While I get no picture ( signal lost messsage) on tv1 (channel 105 for example) I can go to tv 2, turn on channel 105 and get it fine. Ok, I've got a cable problem, right? I switched the cables (tv1 to tv-2, tv2 to tv-1) and for a day, everything was fine. Then same problem. Ran a check switch and everything came up "good". Min. signal strenght on any transponder on the 119 sat is 90 or better, with a few at 125. The 110 sat is a little lower, with the lowest being around 85, highest about 110. Dish is sending a "rebuilt" 522. The unit I have is a new one, about 4-6 weeks old. Two questions:
1- Did I miss something I can check? Does it seem like the 522 is bad?
2- Is a "rebuilt" 522 really "better then a new one" or should I demand another new unit?
Thanks to all who take the time to respond!
