Question about the little red button
leaderc
22
Is there any well to tell what picture quality is being cycled through as you push the button? Aside from the obvious, "what does the picture look like", but is there any way to know for sure you are in 1080i?
Thanks,
Charles
If you are on version 6.20, you can set the resolution in the Installation Wizard instead of using the Red Button. However, if you want the Native mode (where the output resolution follows the source), you still need to use the Red Button.
Perfect, didn't even notice the orange bars on the STB, I'll have to check that when I get home. Thanks gang! And thanks for the welcome, good to be here! :)
Excellent results with silver sensor
OTA Channels Gone
