Question on how to add 4th sat
cmcgrail
45
16
Phoenix, AZ
Hello, I am a new dish customer and would like to have access to either the 61.5° or the 148° satellite. I have a 211 receiver and a dish 1000 looking at 110, 119 and 129. I have an extra dbs dish and LNB that I got from voom which I would use to receive the signal. Since there is only one cable coming from the dish1000 to the 211 could I use a DP21 switch to connect the 2nd dish? Thanks for your help.
The moment you use a switch the DPP Twin's satellite input is disabled. So you can't use a DP21 to combine the 4 satellites. Also, you will need a DP LNB. The Voom lnb won't work.
Once you get a DP Dual or DP single, you'll need a DPP44 switch to combine the 4 satellites. Each satellite needs a cable run to the DPP44 switch.
You could also use a DP34 and a DP21. Run 3 cables to the DP34 (119, 110, 129) and combine one of the outputs of the DP34 with the cable run from 61.5 or 148 using a DP21.
Hope that helps.
Satilite - Cable - Antenna in one cable?
International Channels only receiver addition...totally lost
