Questions about 522 Receiver
DarthZug
12
I'm going to be getting Dish Network soon to replace my Digital Cable Service. My house is already wired. I want to get a 522 and use it in Single Mode on my main TV. I only have one cable going to where my main TV is. My quesiton is how do I hook both turners with one cable? Is there some type of splitter I need to get?
You CAN'T use spitters on an incoming signal. You will need to run a 2nd line in or use a DP44+ switch.
But the installers will get it all going for you when they do the install.
The cheap answer is NO. Run a second cable. *My choice*
THe expensive answer is yes.
With a DispPro PLus Twin LNBF($99.00), DishPRo PLus 44 ($199.00) and seperator ($10.00)
I think that covers it. :)
*Edit* Unless you are doing it yourself, then let the installer run the needed connections like thiggin2 said.
I believe I'll have the installer run a second cable to the outlet in the room I want to have the 522. They'll do that right?
They'll probably run two new lines to replace the inferior cable.
Maybe you meant to say:
DispPro PLus Twin LNBF($99.00) OR DishPRo PLus 44 ($199.00)
Depends on the installer, they usually don't fish lines through the inside of the house down through walls unless it's a fairly easy job. They will opt for going in through the outside walls. But, your mileage may vary.
5 recievers
811 looses video output
