1inch and five eigths outside diameter chain link fence pole that you can find at any hardware or fence dealer. If you are needing height on the poe then I would also get 2 large brass coldwater pipe clamps to secure around the bottom portion of the pole tightly, be sure to dig your hole to a depth of 3 feet and about the diameter of a basketball and use 80 lbs of concrete to secure the pole in the ground. You will also need to make sure the pole is plumb in the cement before it hardens otherwise you will have problems setting up the dish. I would also recommend getting two pvc elbow sweeps or what is also called conduit sweeps to run the coax through at the pole and where it comes up to the house at so as to avoid damage from lawn equipment. Have miss dig come out if the pole is going in a front or side yard, 1 800 482 7171 is the number for miss dig in michigan and it will probably take them up to 5 days to get out to you right now.
Pole length should be 8 - 10 foot, depth of hole should be 3 - 4 foot with any greater lengths not being required, 80lbs of cement will be more than adequate for securing the pole into the ground unless you have high sand and or high water saturation issues.
