Receivers supplied by Bell
marine
Sep 9, 2010
Sweden
Hi, Sweden calling!
Can someone who has a receiver supplied by Bell check if you can amend the Local Oscillator frequencies in it? And if so - what frequencies for which receiver can you find in the OnScreen menu? I'm trying to set up a system with a 10600MHz LNB, but i'm not sure it'll work if the receiver has fixed transponder frequencies and the LO frequency is expected to be something else but 10600. I've seen 11250 somewhere, can that be verified as well?
Cheers, and a good weekend to you all!
You can't adjust or view the oscillator frequencies on a Bell receiver. With a Bell receiver you can "check switch" which determines what type of switches are used in your setup, or you can cycle through the transponders 1-32 when you're installing your dish.
That's it, that's all..... for LNB options.
Bell is DBS which uses 11250 LNB LO frequency
and it wont work in Sweden....footprint is Canada and a smidge in the states
U.S. Networks
Multiswitch Nightmare
