Reception thru screen
BgSat
5
I have moved into an apartment. We cannot have dishes on the outside of the building, however I have a screened-in balcony-like thing that is very small. I should be able to mount a dish out there, but I cannot remove the screen so the dish would be behind the screen.
Is this alright?
Thanks!
What kind of screen are you talking about? Is it like a thin mesh or something like a screen door? As far as the apartment mounting, you may be able to use a tripod or balcony mount and some flatwire.
Try using a jumper cable. One long enough to go from your receiver to your LNB. Use a compass to find your bird if possible and aim the dish by hand. I know it seems primitive but it's fast and easy way to find line of site. Just remember to adjust slowly because there is a slight delay to your receiver.
Thanks for the help.
If I understand you correctly, you are suggesting that I connect the dish to my receiver in the house using x' of coax, then try getting a signal thru the screen.
Is this what you mean? Sounds like a plan.
Thanks again! I so do not want to have to get cable.
Bg
News on HNS Joint Venture
