Remote codes
b0471@kzhosting.com
26
Iowa
Hi, My first time to write in. I have a VIP211 and a Toshiba 42Hm66. I have not been able to find a code to run the tv off 211 remote. I was hoping that someone my have been able to come up with a solution for this. I haven't found anything. Thanks
In User's Guide find "Setting Up Using Device Codes Scan", (that's how it's shown in the 622/722 guide)
Remote codes 42hm66
I tried that first and none of the listed codes will work. I was hoping someone may have had the same problem and had found a code that worked somewhere else.
I'm talking about SCANNING for the codes, not from the lists. It's in the guide.
I tried that too. I'm thinking I going to be out of luck or I'll have to buy a universal remote. Thanks for your help.
Additional Toshiba codes
Here are some toshiba codes not listed in the Dish manual:
10154, 11256, 10156, 10060, 11704, 10845, 11656, 10650, 11356, 0060, 0154, 0156, 1265, 1000, 1049, 1072, 1073, 1104, 1095, 1063, 1052, 1050, 1045, 1109, 1034, 1032, 1014, and 1055.
Hope it's in there!
I gave up earlier this last weekend and bought a Logictech 550. It works great. I'll try the codes and see if they work. Thanks
Yeah, where did you get those at? DISH remote codes are traditionally 3 digits (4 if you set the remote in limited mode).
Most Toshiba's use the same code (095)
In this order:
Hold the TV "mode" button...until ALL 4 "modes" go solid, then let go
While TV is blinking, type in "0", "9", "5". Then hit the "#" button
That SHOULD do it.:)
Now if I could control my Dish Network receiver with my Directv RC-64R remote, I'd be happy!! I have locals with Dish Network and it's annoying to keep so many remotes together. LOL! :D
Yeah, laziness is a bummer: remotes in fam. room: 722, 501, A/V recvr, cd player, DVD burner, old Panny VHS, and fireplace logs.
fred
fred
Good lord, get a universal remote. :) I keep all of the factory remotes in a basket, just in case, but I run everything with a Logitech Harmony 880. Also look at URC remotes (probably what I'll get when the Harmony dies).
The Harmony remotes are Activity-based (what you're doing now with all those remotes is called "Device-based").
SOOooooo much easier for the family to use the equipment when activity-based.
Best money I ever spent.... ok maybe my new table saw would be in there somewhere but you get the idea :D
Two dish 500's
Dish Network Expands Local High Definition Markets
