replaced actuator arm -- now no signal :(
st_moose
24
I had to replace the actuator arm on my BUD and now I have no signal :(
I put the old actuator arm bad on the BUD and still no signal :(
I checked all the cables, all appear fine.
Now of course my LNBs could have gone bad, but I doubt both C and Ku went bad at the same time, if this is not the case what else might have gone wrong?
thanks
If everything was locked down before you replaced the actuator then you should be ok, if they were the same size. If you your polar mount moved during the install, you may have to resight one of your birds but it shouldn't be much of a big deal.
Try to lock in by fine tuning one of your sats, the rest should fall into the arc if you haven't made any adjustments to anything else but your actuator.
Solidaridad 2 at 113.0°W C-band
Mount lnb on Feedhorn
