And just an added thought,a 2 way splitter will reduce signal by 3.5 dbs(decibels),a 4 way splitter will cut signal by 7 dbs.So use a 2 way.
ok. there is a distinct possibility there are multiple problems at work here. dish alignment might still be an issue for example. fatair's correct .... about giving us details about what channels you do get and what channels you don't get will help us help you.Thanks for all the comments. Found splitter. But I am still not pulling in anything that I wasn't before.
Freq and SR? Someone may recognize or take a look here: http://www.global-cm.net/mpeg2central.htmlBut many i cannot confirm which satellite, as they are not listed on Lyngsat
BTW: Have you string tested your dish? Tested to see if the feed is centered and 'square' to the dish? Measure dish and calculate the F/D and focal length and compare to measured? NOTE: this may be off an inch as there can be some measurement/physical variances 'built in'.I am new to satellites. I have a 7.5' Echostar mesh BUD. It came with the house. Hadn't done much with it since moving in
I noticed that you list both horizontal and vertical on same transponder freq.4073/H&V/30000.
Only possible if the Servo Motor on the Feedhorn is not working.Lnb is pulling in horizontal and vertical frequencies regardless of polarity setting.
Ive seen this happen before with a strong transponder and an old lna (low noise amplifier). The receiver may lock with the wrong polarity, but generally the channel wont be viewable.
I have had good results with a BSC421. hypermegasat has them.
