If the dish is falling short of it's destination, then you are adding counts not missing them. Likely suspect is a bouncing reed switch. Hard to tell for sure without a scope picture.
			I've had the same problem,it was always groung this,try that...Get your self a cheapo V-box,program it then see if it takes you to the correct position.I got rid of all the fancy stuff,got a v-box,works every time,had it for a couple of years and very happy.Picked up a couple of extras for back ups.Just try it,it works for me,everytime.If you have been following me at all, you know i have had an ongoing issue with my actuator not keeping track... The problem is actually getting worse, and its driving me NUTS. I have to figure out what is wrong.
Here is the issue : I am always am short WEST. I guess that makes it easier for me to lock a bird, as i always know which way to nudge the dish. But it is getting so bad, i have to hit the Diseqc move command about 8-10 times to get back on bird. (again, always to the West).
Nothing is loose on the dish. Heck, i have welded just about everything. I have the ASC1 and a Venture MaxiBall. I have the dish grounded to the House Panel Ground. I am using shielded wire. I even have a capacitor between m1/m2 at the motor. Where the heck do i look? Bad cable? (2 years old) Bad ASC1??? Bad senor in the Actuator??? Something else???
I maybe hallucinating, but i do believe the problem is getting progressively worse.
HELP!!
IBoston, you mentioned in an earlier post you had a capacitor between the M1 and M2 terminals. Do you know the value of this capacitor? If it's really high it might overload the ASC1 for a split second causing it to miss some counts...
I used to get some missed counts once in a while so I just added a 30uF ceramic disc cap across the sensor terminals. That seemed to work, at least so far.
This was one of the fixes i tried. So, its not the capacitor that started this problem.But, keep the ideas coming...
But, to answer your question :
1000uF / 1000MF 6.3V RADIAL ELECTROLYTIC MOTHERBOARD CAPACITOR
Is this not okay??
Okay, i got the new :
NON POLARITY 22UF 22MFD 100V ELEC ALUM AXIAL BIPOLAR CAPACITOR 13X26mm 20%
And new Super Reed II Sensor.
I installed them Both. I know putting both in at the same time (if problem fixes) won't tell me which fix it was, but at this point, i don't care, i just want it to track properly!
Give me a couple days to find out if this fixes the problem. It's hard to just replicate, as sometimes i can swing across the arc and back and it tracks, and sometimes not, so the best way to know for sure is to play with it for a few days and see if the tracking is getting off.
