Would recommend that you take this in two steps:
1. Install as a fixed dish system (without motor). Download the expanded microHD manual that provides extensive step by step installation instructions. Get comfortable with the operation of the receiver and locating a few satellites.
2. Add the motor a few weeks down the road once you are familiar with the basics of your system.
Jumping into the complexities of a motorized system without having an understanding of the basic operations of a FTA system can be quite daunting!
To get your feet wet, select 83w K AMC9 and preprogrammed transponder 11735.
Set the dish to this approx. aiming:
http://geosatfinder.com/Reports/SatAim.aspx?Longitude=-82.72416&Latitude=38.52006&SatIds=191
Set a small TV next to the dish a slowly paint the sky 15+ degrees on either side of the compass reading. If no Signal Quality reading, increase or decrease the dish elevation in one degree increments and repeat the slow painting motion. Once you observe a Signal Quality reading over 50%, scan the satellite using Single Satellite Search and either preprogrammed TP or Blind Scan All.
Good luck!
Good luck!
