Setting up conical feed questions
jcardani
12
Southern NJ
Hi All,
I will be seting up a conical feed on my Fortec 1.2m soon and have some questions.
First, where should the feed be positioned on the LNB (at what F/D line?) Should it be lined up with .6 since the dish is a .6F/D? Iceberg's pictures on his review of the conical feed appears to not be at .6 but it's hard to see. BTW I have the DMX741 C/Ku band LNBF and not the GeoSatpro he was using. I want to make sure the dish is illuminated properly.
Also, is the focus point the same for C and Ku band with this LNB?; ie if I set the focal length both C and Ku would be correct.
Joe
I think you'll have to play a little , Joe. Once I got a signal on my lnbf WITHOUT the scalar, I optimized that manually. Then I put the scalar cone on the lnbf . Beginning at the very end and moving away from the dish, my best spot seems to be about 1" to 1 1/2" from the mouth of the feedhorn. I use STO on Gal 23 (121W) as a target since it's loaded with power. Since , by definition, this C-band lnbf is mismatched to a Ku band dish, I wouldn't rely too much on trying to "calculate" the sweet spot. It's quicker to actually determine it logically in incremental fashion.
my LNB is set up almost like Brent's in regards to the depth of the LNB
I'll take a pic of mine later
Setup for 93/95/97/101
Is RTN becoming RTV?
