SG2100 Help!
Spin
188
State of Confusion
Ok here's the problem.
I'm set at my true south at 93 T6... I have a 76cm winegard dish. I get every sat on the list up to 121 degrees. But I can't get anything on G10R. What's going on? Any clues? I have a 82 quality level on CBS Newspath on my true south. Pulling anywhere from 60 - 85 on other sats and transponders. But G10R Nada.
I have noticed the signal quality to be a bit lower than usual on some TP. on G 10, that will not help I guess. What TP. are you using?
I find KFDF/KPBI to be the strongest..
12112 MHz (V) SR : 4.444 Msps
Or maybe its a line of sight issue?
There is a tree in that direction but it doesn't effect the 121 sat.. would 2 degrees make that much difference?
spin
where ya located? Maybe we can see if the numbers are right...
but yeah the tree could make a difference
Springfield MO 65804
I'm getting the tree trimmed down and in soon. If thats the problem it will fix it.
I forgot you have a motorized system.
My true south is 93 too :) (Minneapolis, MN)
sounds like that tree is in the way...what happens when you try IA7 or H1 (127 & 129)?
Best motorized budget system?
What Is The Best Dvb Software Out There?
