SHAW: can't get ch 400 [horizontal chs?], but get others .....
dean42mvg
11
usa
i went on seasonal break, but then couldn't get signal on channel 400 when i re-connected.
i can get signal of 86 on channel 299 / 308 etc and a clear picture.
called shaw, they said it was bad multiswitch, because i couldn't get horizontal channels. so i bought a new quad [old style] LNB
still wont work. factory resets, shaw sent hit
i can get signal of 86 on channel 299 and a clear picture. green light. provider 4128 Sat A4
but if i go to channel 400, red light 4128 Sat A4 0 signal
Sounds like you might need to factory reset the receiver then get a fresh hit, might have a bad software download.
no go.
i had unstacked being sent already.
i see via options 64 'authorization status' for ch 400 as US
on channels I GET, it say S
okay, i can unplug the DSR 205 for 5 minutes.
then, turn it on & get TSN [400] for about 3 minutes, then red light / no signal
any thoughts ?
can't edit post #1
here are the actual symptoms:
power cycle DSR205
i can get TSN [400] perfectly for 3 minutes [see strong signal in pics]
after 3 minutes, the light flashes red / green/ red / green / red
no picture
no signal [no horizontal channels]
then i power cycle DSR205 again
no picture
Update ....
i broke out my old tripod & moved the dish a few feet and raised it a few feet.
then, i had problems with the receiver's AC adapter and i replaced it using 12V 1000mA, instead of 12V 1.25A
fired up the system, and have had TSN 400 for 30 minutes.
will leave this setup til the morning & if still green continuously, i'll move the dish back, to determine if it is the adapter or location ...
put the dish back in the original location.
still going strong on TSN 400
was a bad AC adapter that powers the DSR205 reciever
jeezus !! that was a TOUGH ONE !!
