ShawDirect HD install help needed - located in Harlingen, TX
thanks, i'm still up north knee deep in snow but this should work when i get down there to thaw out
It's been raining "Cats and Dogs" overnight here in Vancouver (supposed to go to about 12° C today) but it's better than snow...
I plugged in the following ZIP in Dishpointer and got:
Address: HARLINGEN, TX 78550
Latitude: 26.2419°
Longitude: -97.5836°
Satellite: Starchoice 107W & 111W
Elevation: 56.7°
Azimuth (true): 204.9°
Azimuth (magn.): 200.3°
joshuals has a good post in the following thread on how to set-up a SD dish. (You should try to get a 75e - or equivalent - for Texas.)
http://www.satelliteguys.us/canadian-satellite-services/235802-austin-tx-help-me-get-started.html
It's really a "paint by numbers" approach once you have the mast for the dish vertical in both planes (plumb) with the starting data points above.
If you can put (temporarily) a reciever and a small TV near the Dish when setting up it makes it even easier.
Shouldn't be a problem - I'm south of Houston and have no issues with receiving SD - now, as for my neighbor's "weed tree" (the one that is growing up in the 1 in between his shed and our common fence) - makes it a pain in spring until the weed gets pruned...
No audio on TVO- Shaw direct.
NIMIQ 1 and NIMIQ 2 on the same dish possible?
