signal booster?
Carta
63
Northeast PA
I have a Motorola signal booster. "One in, One out"...It's connected at side of house and distributes to 6 tv's.....Signals are great, but at random times there is no signal...What can the problem be? It happens to certain tv's at certain times. Do you recommend stacking w/ another booster? Thx...
Seems like replacing it is a better idea. Do all of the televisions go out at the same time?
No,, All do not go out at the same time... One goes out; the others stay on....Not always the same tv..
I would check all of the connections and cables first. It sounds like you may be splitting the signal too many times. Have you tried using each television by itself? You should terminate the other lines when/if you do.
Im not confidant that the amp is causing your problems. Unless you have internet or phone, then your upstream might be out of wack, but i would take a guess and say its a signal issue, you do have an amp in the first place after all, the 'correct' way to fix the problem is to have your house rewired with RG6
Retrans Revenues Growing Faster Than Expected
Any Room DVR?
