Signal Quality numbers and more
Sean Mota
19,039
1,739
New York City
Here are my signal quality and power for all HD channels. I am keeping these as a reference point. One more interested piece of information is the EMM information. Three Channels per EMM. If you count unique EMM, the total is 13 (Voom has 13 TPs available) There are only 5 more HD channels that can be fit using 3 per channels.
These are the five HD channels that I assume they may add.
  • TNT-HD
  • Encore-HD
  • Playboy-HD
  • ESPN-HD
  • PPV-HD
Now if MPEG-4 comes around soon, it will provide more space for a few more HD channels.
They also can eliminate INVOOM and get another channel or consolidate the CINEMA 10 channels. I do not see the consolidation happenning.
Code:
[b]Channel	Description	Signal	Signal	EMM
		       Quality	Power	Provider[/b]
101	Cinema 1	53-54	60	154
102	Cinema 2	51-52	60	154
202	HBO West	53-54	61	154
601	DHDT	        52-53	58	15a
241	SHO East	51-52	57-58	15a
124	Rush	        52-53	57	15a
501	Bravo	        52-53	58	15c
311	NFL	        55-56	58	15c
242	SHO West	55	58	15c
251	TMC	        51-52	60	15d
127	Treasure	 53	59	550
129	Moov	        53	59-60	550
130	Animania	52-53	59	550
105	Cinema 5	52	58	553
108	Cinema 8	54	57	553
125	Rave	        55	58	553
262	Starz West	44	59	556
261	Starz East	43-44	59	556
103	Cinema 3	53-54	60	557
104	Cinema 4	54	60	557
201	HBO East	56-57	61	557
121	Monster	        49-50	60	55a
122	Epics	        48-49	60	55a
123	WorldSport	50-51	60	55a
100	Hdnews	        53-54	60	55b
126	Ultra	        56-55	61	55b
128	Gallery	        55	61	55b
106	Cinema 6	54	60	55e
107	Cinema 7	54	60	55e
221	Cinemax East	55	60	55e
109	Cinema 9	53-54	59-60	55f
110	Cinema 10	52-53	60	55f
222	Cinemax West	54	60	55f
999	INVOOM	        51	58	159
Signal Quality Numbers
I noticed that your signal quality numbers are between 50 and 60. Is this the norm for most VOOM installations ? I am currently a DirecTV user with the HD package and have decided to try VOOM out. My installation date is supposed to be March 31.
My signal quality for D* for all transponders is between 98 - 100 depending on cloud cover. Is D* inherently characterized by better signal quality as compared to VOOM ?
The scale is different. That's why we can't compare the numbers.
Is there a quick way to gather that info or did you have to manualy one at a time check and make note of the results for each channel? :eek:
Manually one by one... I have yet to do it for Playboy-HD and Encore-HD. I also want to do it for the SD channels. But it is a hell of a job. If you can help me do it for the SD channels. Take the Movie premium channels or another block of channels and let me know. This way will know how many SD channels/transponder as well as HD/transponder.
I think also that V* only has space for three more HD channels assuming that my hypothesis is correct 3 HD channels per transponder (13 Tps).
Gr8Reb8 said:
Are not the numbers different with the 5c software?
Yes, in terms of quality and strength but the EMM Provider (which somehow I think is related to TPs, don't know for sure) should have remained the same. I care more about this number than the quality and strength. I want to see how many channels SD & HD they are putting per EMM Provider. Soon we will have a complete analysis of compression ratio of VOOM for each HD channel and we will compare that to D* to see the differences. Stay tune. A lot more to come.
Sean, for your prediction of upcoming channels, PlayboyHD came true, what about SpiceHD? Is it on the backburner?
Don't know... as you can see there's not much bandwith left (assuming I am right)? Tell you what I rather have Hustler-HD instead of SpiceHD. We will get SpiceHD programming on Playboy-HD (same company). Also, VOOM should start moving to MPEG-4 or they are going to run into problem.
ESPN-HD should be next...Look for it in the near future. As to prediction, let me not take credit for that as it was announced in a press release and we knew that it was coming.
I don't know how close the problem is. They have redundant programming with 2 HBO HDs, Showtimes. Plus, NFL-HD is pretty much a waste. They could clear up some channels quick, I think.
those living in the west coast, will disagree about the HBO-HD West. NFL-HD right now is inactive except for the game of the week. They can put the programming in the demo channel and free space for one more channel.
I couldnt give a racoon's bottom 'bout dem granola eatin' hippies. I want ma NASCAR in the HD.
I Went To VOOM Because of the East & West Coast Feeds. If VOOM Went Tthe Way of D* & E* and Only Do East Coast Feed I Am Out Of Here & Back To D*.
Sean,
If Voom gets itself into an HD bandwidth problem, I suggest they reduce the number of channels assigned to the exclusive 21. Cinema 10 could easily be carried on 3 channels given the very frequent repeats. Eventually, Cinema 10 could be handled on one channel when the Voom HD DVR is released. The HD channels in the 120 - 130 range could easily be combined and carried in about 5 channels.
Personally, I have yet to watch a Voom SD program as I subscribe to all of the SD channels offered by Dish Network.
Derek
Derek,
I agree with you... but VOOM might not agree with us. From a marketing point of view they won't do that just yet. They might change to MPEG-4 before doing this.
