Last weekend I did some changing around the antenna farm. One of the things I did was eliminated the 4 way switch and added a 2 way switch after the motor. Put the DBS LNBF next to the KU band one. I also had to run a new cable from the motor to the house, as the other one wasn't long enough.
Since I have done these changes, it seems like my signals are down. CCTV, which I can pull a 80 easily is around 60, Doc is around 60 and ONN is around 70 (should be 90). So I messed around with it yesterday.
-Elevation is right
-bypassed switch (same results)
But what is weird is when I unscrew the coax in the back of the Pansat and just leave the pin in 9cable is in the unit but barely) I get a 90 on CCTV. I don't think it's a grounding issue, as the cable connectors were put on right.
Tried to swap the cable last night, which became a mistake (it was getting dark quickly). I hooked 2 sets of 2 cables (connected together) and both gave me same results…the receiver made it look like it shorted out. It wouldn't power on.
I was able to hook everything back up as it was and the unit worked as it was before. More work this weekend but I'm trying to figure out where the issue is ?
The only other thing is the DBS LNBF eye is next to the KU Band eye (they are touching)….this wouldn't screw it up…….would it???
-Elevation is right
