Sling Adapter and VIP 722k not working no led light on adapter
marathon_1
55
Orange County, CA
Dish has replaced my sling adapter and VIP 722K receiver. I plug the sling adapter in to the 722 receiver and no led lights come on the sling adapter. Chatted with advance tech support and tech is going to submit a Technical Problem.
Anybody else have the same idea or suggestion to get it fixed.
I haven't tried this, but it seems to me that the Sling Adapter light should come on when plugged into a computer's USB A port. This might help narrow down the possibilities between Sling Adapter and receiver. Another back door way to check the receiver is to plug in an EHD or thumb drive (for pictures) and see if that works.
External hard drive works fine when plugged into the receiver. If somebody wants to try plugging your sling adapter to a pc USB port and let me know if the sling adapter light comes on, that might up resolve it.
dwarren2 said:
Have you tried both usb ports. Have you run the set up for your wired/wireless network yp make sure your receiver is connected to the net?
Yes, external hard drive works fine, either USB port on 722. Receiver is on the net.
Try using both usb ports . try using a phone charger to verify the receiver usb ports work. Try removing the sling and then go to menu 6-3 and reset connection followed by a reset. After that plug the sling back in and wait 3 minutes and reconnect it. If it still won't light up get a replacement sling. If that doesn't fix it then it has to do with the receiver and you should replace the box.
L754 on 722K
why is it dropping transponders with good sattelite strenght ?
