Some HD not tuning in...
davec53
59
14
This has been going on for me over the past week or so, that when we are watching certain HD channels, the signal starts to degrade and break up...very similar to what it acts like when a strong storm is approaching.
Often, the channel will completely go away and the "searching for signal" screen will pop up. It is always 129 that is giving the troubles, and sometimes after scanning all of the transponders, the channel will still not show up, and we get the message to either hit Up or Down to change to another channel or hit Recall.
I have not studied it close enough yet to see if there is a pattern about which ones are crapping out...Today, I could not watch Science HD, but I could watch USA HD, and I've noticed it quite a bit on TBS HD over the past week.
Right now, for example, Science HD and TBS HD are still not tuning in, but TNT HD and ESPN HD are coming in...
Very odd, and just wondering if anyone was experiencing similar funkiness...
btw...i'm located in Kentucky.
Sounds for sure like you have a 129 issue, probably an alignment problem. Check several of the transponders on 129 from the point dish screen
scifi, tnt, and espn are not on 129 which is why you could see them. definitely sounds like you could use a repeak.
yep...i had checked signal strength, and most of the 129 transponders were very low.
we've had some pretty rough winds the past couple of weeks, so maybe that has moved my dish out of alignment.
i just wanted to check and see if anyone else was having trouble, or if i was going to have to either call someone to re-point things for me, or maybe take a chance and try it myself.
anyone who has done it before...is it a difficult procedure, getting lined back up?
You are already very close, all you need to do is make very small adjustments to azimuth and elevation (only one parameter at a time) to get your signal strength back.
sounds fun. :)
so the azimuth and elevation...those are given to me by the dish, in the setup menu, is that correct?
i may try to fix it myself.
i noticed today that all of those 129 channels come in fine during the morning hours, but by this evening, they are not tuning in again.
sounds fun. :)
How did it go? My dish just started losing it's 129 signal starting during the evening. Guess it's time to get the tools out and change the alignment.
i haven't gone out and made the adjustments yet. was starting to sort of think that maybe it was a tree out in the front yard causing some of the problems...it has only gotten fully covered in leaves over the past 2-3 weeks....about the same time my issues started.
i went out and looked last night, and it doesn't really seem to be in the way of the dish, but then again, i don't really know where the 129 sat is in the sky at any given time.
I had the same issue where my signal would degrade for 110 after the leaves came. Even though the dish appeared to clear the tree to the left it was still blocking the signal.
i may do a little tree trimming this evening...see if that helps. that would definitely be easier than getting up on the roof and fidgeting around with things. :)
I am having the same issues with 129, luckily, I still have my 61.5 dish up on the roof, time to change some cables. I think a tree is in the way of 129 on the main dish.
I am also having the exact same problem with satellite 129, and I'm getting pretty fed up with it. Before I upgraded to HD, satellite 110 was rock solid for me. Since upgrading and adding the new dish to pick up 129, my 129 dish has had to be realigned by techs 5 times this past year. Now, it's off again.
None of the techs have been able to get very strong signal strength on it, but the dish is free and clear of any obstructions. What sort of signal strength levels are typical for you all on 129? I'm going to have to get out on the ladder after work today. Thanks.
Can I get max for a penny?
Brand New 722 Reboots After 5 Minutes
