Spotbeam Testing 61.5
mike123abc
Too many cables
25,862
5,194
Norman, OK
What does QPSK and 8PSK mean?
QPSK or 4PSK is 2 bits (4 states) per symbol or waveform
8PSK is 3 bits (8 states) per symbol
8PSK is 50% more data per symbol then QPSK, but it requires more power since the receiver has to figure out which of 8 possible states the waveform is in verses 4. So, more error correction is used, so not 50% more but about 30% more data in practice.
charlesrshell
SatelliteGuys Crazy
11,327
6,076
O'Fallon, IL
OK, thanks
broadcasttheworld
152
Now another question about Cleveland Locals. I have a Dish 1000 system and I see our locals on planned to be online at 61.5 which I do not get. However Sports Time Ohio is on 129. Can I just add another dish without getting rid of my Dish 1000? Can I simply add 61.5 or a 4th bird using a switch? I have an old Direct TV dish similar to the dish 300 system could I just get a lnb for that and aim it at 61.5 add it to my dish 1000 using a switch? I want both 129 and 61.5
digiblur
14,190
4
Louisiana
You can't use legacy LNB's such as your old DirecTV dish one. Depending on your configuration you can tie in another orbital position to the Dish1000.
broadcasttheworld
152
Would it be possible to remove the 129 LNB from my Dish 1000 place it on the Direct tv dish and tie the coax into the 129 spot on the Dish 1000 to pick up 61.5?
TheKrell
A mighty and noble race originating on Altair IV.
39,103
47,136
Fairfax, VA
I think the answer is "Yes", though Dish LNBs attach to an arm with a D-shaped cross section. Direct dishes have a rectangular support arm. So electrically this should work, but mechanically it might not fit.
broadcasttheworld
152
Fine I guess I will just pay the 100 bucks and have dish come out and do it. :-) Thanks for the help.... :eureka
primestar31
15,080
18,191
Beta Omicron Delta III
Is there anyway to test if i'm covered by the spotbeam that includes NYC?
Is there a transponder I can test on 61.5?
The easy answer that nobody seems to be providing you, is if your present dish ends up being a little small for the new spotbeam, you can simply put up a larger (maybe even dedicated) dish pointing directly at 61.5. That will get you more signal, and that's all you need.
ats7627
341
4
Since you guys are distributing the surplus spectrum analyzers how about sending one my way.
I have a surplus spectrum analyzers I'll send you.
As long as you'll send me your surplus $3500.00.:D
Smith P.
On Vacation
Oct 4, 2003
8,907
Bay Area, CA
Testing tp13 in CA today.
622 HDMI died overnight?!?!
Starz & Dish Network Launch Multi-Tactical Marketing Campaign
