bwaldron said:Well...I'm probably not expert enough to answer your questions.
While I installed my D* and (former) ExpressVu systems myself, I had my old BUD installers do the *Choice dish for me, as I had them out here anyway to take down my old damaged BUD. They pointed the dish with a meter, but then peaked the signal using cellphones with one guy at the dish and one inside at the receiver looking at the onscreen EcbNo. My understanding is that the ECBNo is a S/N measure.
As far as signal between the two birds, I am not seeing big differences between them (until F1 was swapped out last year, it was a good bit weaker than F2 here). I do, however, see larger signal quality variance among the transponders on F1 than I do on F2.
In case it helps, right at this moment I am getting an ECBNo of +10.1 on 299 (F1) and +8.9 on 281 (F2). Fairly sunny and clear here now that a thunderstorm has passed.
The same edge that I've circled in blue, only I've circled it on the other side since the pic doesn't give a view of the edge that we're talking about. I'll be using a guage but I wanted to rough it in before going on the roof-105 degree temps here lately-in the shade..HDTVFanAtic said:I first did mine without the bolt on the side (the left side on the above picture) - putting in on last.
I was just as confused as you - and the instructions on the other site are not that great - as you noted.
There is an edge behind the opening where the bolt mounts - to the left of the tip of arrow denoting the skew.
That was what I finally decided was the indicator - and what I think Ice is referring to as well - of course you cannot see it if you have the bolt in place.
I guess they assume most will use a gauge to set the elevation and fine tune it with a meter - which obviously is the final step anyway - but they certainly could not have made it more difficult.
keenan said:The same edge that I've circled in blue, only I've circled it on the other side since the pic doesn't give a view of the edge that we're talking about. I'll be using a guage but I wanted to rough it in before going on the roof-105 degree temps here lately-in the shade..![]()
299 is on both satellites.keenan said:F
AIUI, 299 is on 107 correct?
Okay, so even though I see no HD channels listed in the guide, everything is good on my end?Satellite Expert said:299 is on both satellites.
You are ready for the next step. Your broker has to tell SC that you have a non stacked elliptical dish and that you want the HD turned on.
After authorization, check your F2 signal strength on the HD channels and 420 + 559. You will notice a variation on different transponders
keenan said:Okay, so even though I see no HD channels listed in the guide, everything is good on my end?
What about those commands to get into the diag screen..? Will those work after activation?
One other thing, the time displayed on the front panel is wrong and the guide date is wrong as well, I'm guessing that will be rectified upon activation...?
