Strong Active C-Band Transponders
Babadem
2,307
177
MA
I need Strong Active transponders to aim my C-Band Dish for the Satellite locations as indicated below. Any feedback will be highly appreciated.
  1. Amazonas @ 61.0°W
  2. Galaxy 25 @ 93.1°W
  3. Galaxy 3C @ 95.0°W
  4. Galaxy 19 @ 97.0°W
  5. AMC 1 @ 103.0°W
1. trees in way....so no clue
2. There is nothing on that satellite on the C-Band side
3. 4167 V 6617 (Univison)
4. 3843 V 2893 (Legacy TV) or 3851 V 9983 (AMG TV)
5. 3840 H 26681 (Ion)
Thanks, Ice for your input.
I want to add my thanks too. I'm putting the big dish on the pole this weekend and was going to ask for strong transponders on 95 and 97.
I sit right at ~96w so I plan to set my true south by splitting 95 and 97 on my azimuth setting.
Either of those satellites would be used to set your elevation, not azimuth. Azimuth is adjusted towards the horizon, where the actuator movement of the dish is more elevation than E-W.
Azimuth as in pointing to true south. Like 180 degrees. Like the top of the arc. Like a bearing. Like "which direction you goin', boy?"
Hitting a satellite takes both azimuth and elevation. Establishing my true south can eliminate a bunch of tweaking when I start to follow the arc. Hence my desire to point my dish with the mount referenced on true south. Same thing as pointing your small motors to true south.
That's my plan anyway.
61w 3767 H 1600
For the life of me, I can't lock onto this or any other C-Band transponder on from this bird. Are there really any active C-Band transponders there? :(
There are three channels I receive all the time at 61W plus a couple feeds that come and go. I will report SQ when I get home tonight. The channels are all in lyngsat CEV,TV Clube, FGV.
Please, include the parameters when reporting your findings.
If you are going to get your true south by finding 97 on your pole and marking it, then finding 95 on your pole and marking it, then turning your dish to be right in the middle of them, that should work pretty well.
I can say that when I first got a big dish, not correcting for that small difference between my geographic longitude and the longitude of my southernmost satellite, caused me to miss about half of the satellites I was trying for.
The only thing I can say about zenith is that, on some big dishes, it's hard to tell exactly where that is. On my Birdview, for instance, I have to use a big framing square, held against the back of the dish and the rectangular steel of the mount.. On my first big dish, there was a place I could glue a paper protractor, with a piece of semicircular plexiglass over it. That assisted me in a lot of ways. Nowhere I can put one of those on my BV.
I think it pays to get zenith as precisely as you can, using measuring tapes, squares or whatever other tools you need. It will pay dividends in hitting satellites to your far east and west.
CEV 3989 H 1599 SQ bouncing 36 to 44% - SBT 3941 V 3479 23 to 32% Pixelating - FGV 3925 V 2222 32 to 39% - 10ft Unimesh BCS621 LNB Micro HD Receiver - Heavy overcast\Windy\Rain.
CEV has changed freq. from what I originally reported. Lyngsat is currently wrong. Woohoo at 4168 H 3461 use to be here as well, but haven't been able to lock it for quite some time.
TVBB 1, 3630 H 2785 - FGV, 3927 v 2222 - TvClube, 3925 V 3333 - UNYCA, 4164 H 3846 - jives with http://www.lyngsat.com/Amazonas-1.html
3767 H 1600 is dead, CEV EaD is on 3990 H 1600 as I post.
Woohoo at 4168 H 3461 is here, but weak today- 42Q
Thanks a lot, guys. I will check these out when I get home.
Looks like Fat Air is in Wyoming. According to Satbeams he should have a stronger signal. You might want to check your location. If you are in the northeast it's a fringe area.
With the exception of Woohoo at 4168 H 3461 that came and went...........they all came in. Thanks, again guys! :D
I've lost my G 16 Caribbean channels for NBC and Fox
EWTN (G1-11) leaves analog
